Wireless data recorder
The OM-CP-RFRTDTEMP101A is a battery powered precision temperature recorder and wireless transmitter. The compact, portable device records up to 5,461 measurements. The unit combines the features from the standard product line and adds the convenience of a wireless transmitter. When enabled, the wireless transmitter will transmit readings back to the host computer where the data can be analyzed...
The OM-CP-RFRTDTEMP101A is a battery powered precision temperature recorder and wireless transmitter. The compact, portable device records up to 5,461 measurements. The unit combines the features from the standard product line and adds the convenience of a wireless transmitter. When enabled, the wireless transmitter will transmit readings back to the host computer where the data can be analyzed in real time. These readings are also logged to the device’s memory for added data security.
Omega Engineering www.omega.com
