Welder/generator controls dc output
Ranger 275 engine driven welder/generator with Chopper Technology controls the dc output to create an arc with improved welding performance. The unit supplies 275 amps of dc welding power at 100% duty cycle and 9000 W of ac auxiliary power.
Ranger 275 engine driven welder/generator with Chopper Technology controls the dc output to create an arc with improved welding performance. The unit supplies 275 amps of dc welding power at 100% duty cycle and 9000 W of ac auxiliary power. It can be used with stick, TIG, cored wire, MIG, and air gouging with carbon rods up to 3/16-in. diameter. The 20-hp, air-cooled gasoline engine has a 9-gal. fuel tank.
The Lincoln Electric Co.
www.lincolnelectric.com
