Wago Topjobs 24 diode, disconnect and LED terminal blocks
Wago Corp. has added 24 disconnect, diode and LED terminal blocks to the TopJobS terminal block line.
06/30/2009
Germantown, WI – Wago Corp. has added 24 disconnect, diode and LED terminal blocks to the
Wago TopJobS line expands
The specialty feed-through blocks accommodate conductors AWG 22–12, and are available in 2-, 3- or 4-pole variants with single-, double- or triple-deck configurations. Each DIN-rail mount block utilizes the standard TopJobS profile for seamless integration. Upcoming fuse terminal blocks variants will offer additional flexibility within the same compact footprint.
The blocks feature a Wago -exclusive staggered jumpering system for convenient potential commoning and traditional push-in jumpers. Topjobs specialty blocks also provide the greatest range of marking options including center and side marking locations, as well as marker tab and continuous marking strip adapters. Disconnect terminal blocks feature a test plug conveniently located on the side of each knife disconnect.
TopJobS specialty blocks employ push-in terminations for ferruled or solid conductors. Termination of stranded conductors is also simple, insert a screwdriver into block’s port to open clamping unit, push-in the conductor and remove screwdriver. Cage Clamps Spring Pressure Connection Technology ensures all terminations are vibration-proof, maintenance-free and immune to temperature cycling.
Wago Spring Pressure Connection Technology eliminates loose wires resulting from vibration and temperature cycling, while providing highly reliable, corrosion-resistant and maintenance-free connections. www.wago.us
TopJob-S series 2000
- Edited by Mark T. Hoske, editor in chief, Control Engineering , www.controleng.com
More about system integration ; Sign up for a free Control Engineering eNewsletter .
