VFD supply cable resists severe voltage spikes
Variable frequency drives cable is a inverter-grade, flexible motor supply rated at 1000 V/3000 V peak.
Variable frequency drives cable is a inverter-grade, flexible motor supply rated at 1000 V/3000 V peak. The cable withstands severe voltage spikes generated by power distortions, and features a bend radius of 12x cable diameter, 194-F dry/140-F wet or oily operating environment, and VW-1 flame resistance.
Olflex Wire & Cable, Inc.
www.olflex.com
