Vented indoor enclosure
The T1FLO Type 1 vented indoor enclosure features an active cooling ventilation system with a factory-installed fan, a vent, a filter and a thermostat.
The T1FLO Type 1 vented indoor enclosure features an active cooling ventilation system with a factory-installed fan, a vent, a filter and a thermostat. It offers rugged 14-gauge steel construction for durability — with solid or perforated accessory panels available — and features a lift-off hinge door for simple component configuration. It comes standard with mounting holes, a terminal block power connection for the fan, external mounting feet options and a secure, slotted quarter-turn latch. The unit also meets UL, NEMA/EEMAC and CSA Type 1 industry standards.
Hoffman Enclosures
www.hoffmanonline.com
