Vent removes air in hydronic systems
Spirovent eliminates all free and entrained air and up to 99.6% of dissolved air in hydronic system fluids. The need for frequent bleeding, purging, and venting is eliminated along with air related system noises, such as gurgling and the waterfall effect.
Spirovent eliminates all free and entrained air and up to 99.6% of dissolved air in hydronic system fluids. The need for frequent bleeding, purging, and venting is eliminated along with air related system noises, such as gurgling and the waterfall effect. Heat transfer is enhanced due to lack of an air/water mixture, and the need for rust inhibiting chemical treatment can be reviewed. Vents are available from 3/4-36-in. pipe size for flows up to 30,500 gpm.
Spirotherm, Inc.
www.spirotherm.com
Circle 384
