Valve actuators handle most water applications
DuraDrive actuators and linked valve assemblies provide the flexibility to meet most hot and chilled water and steam applications.
By Staff March 1, 2000
DuraDrive actuators and linked valve assemblies provide the flexibility to meet most hot and chilled water and steam applications. Ball and globe valve assemblies, with the actuator, are available in two-position, floating, or proportional spring return and nonspring return models. They can be mounted on 1/2-2-in., two and three-way valve bodies using specially designed linkages.
Invensys Building Systems
www.invensysibs.com
Circle 385
