USB digital IO module for industrial environments
The USB-DIO24-CTR6 is a multifunction USB device that can be used in light, motion, and process control applications.
By ACCES I/O Products, Inc. August 9, 2015
The USB-DIO24-CTR6 is a multifunction USB device designed to add portable, industrial strength digital I/O, and counter capabilities to any PC or embedded system with a USB port. It can be used in light, motion, and process control applications. It features 24 lines of CMOS/LVTTL high-current digital I/O with two fully-undedicated 82C54’s, yielding 6 counter/timers and access to the input, gate, and output pins, all packaged in a rugged industrial enclosure. The USB can be used in industrial environments, desk, or testing stations and utilizes a high-speed function driver for maximum data.
www.accesio.com
