Tube, ceramic heaters
Space-Ray Infrared Heaters will show its complete line of tube and ceramic heaters including its recently introduced positive pressure low intensity tube heaters with its patent-pending Innovative Tube Integrity Safety System at the upcoming AHR Expo in Orlando at booth 1410. In 2009, Space-Ray celebrated its 60th Anniversary since it manufactured its original gas-fired burner, entering the bus...
Space-Ray Infrared Heaters will show its complete line of tube and ceramic heaters including its recently introduced positive pressure low intensity tube heaters with its patent-pending Innovative Tube Integrity Safety System at the upcoming AHR Expo in Orlando at booth 1410. In 2009, Space-Ray celebrated its 60th Anniversary since it manufactured its original gas-fired burner, entering the business in 1949. According to Space-Ray, the TISS System is a low voltage circuit that continuously monitors the clearance between the top of the reflector and the ceiling for excessive heat and tube integrity compromise. If the heat increases due to the unlikely event of heat exchanger failure, the wire melts, the safety circuit is broken and the gas controls shut down.
Space-Ray Infrared Heaters www.spaceray.com
