Trolley hoist
The SHB industrial grade chain hoist and geared trolley configuration minimizes beam-to-hook distance for use in applications where longer hook travel is required. This low profile trolley hoist is available in 1-ton through 10-ton capacities and comes with standard 20 feet of lift. Its features include an efficient drive train that minimizes the effort required to operate and maintenance-free ...
The SHB industrial grade chain hoist and geared trolley configuration minimizes beam-to-hook distance for use in applications where longer hook travel is required. This low profile trolley hoist is available in 1-ton through 10-ton capacities and comes with standard 20 feet of lift. Its features include an efficient drive train that minimizes the effort required to operate and maintenance-free and lubed-for-life sealed ball bearings for smooth movement.
Harrington Hoists, Inc.
