Triple outlet power supply
The MX180T is a 357 W triple outlet power supply with eight ranges.
The MX180T is a 357 W triple outlet power supply with eight ranges. Outputs one and two can provide up to 180 W in three ranges 60V/3A, 30V/6A, 15V/10A), with four further ranges available on output one, with output two disabled, to provide up to 360W from a single output (120V/3A, 60V/6A, 15V/20A). Output Three has two ranges: 5.5V/3A and 12V/1.5A, both with adjustable constant voltage and constant current capability. All outputs are isolated and independent, but voltage tracking can be selected to make two or even three outputs track a single voltage control.
Saelig Company, Inc.
