Transducer measures six parameters
Series DME 400 programmable ac power transducer measures up to six parameters with four analog and two digital outputs. On a three-phase system, it can measure voltage and current, as well as active power or watts and reactive power or power factor.
By Staff August 1, 1999
Series DME 400 programmable ac power transducer measures up to six parameters with four analog and two digital outputs. On a three-phase system, it can measure voltage and current, as well as active power or watts and reactive power or power factor. Limit readings and metering information is available on digital outputs.
GMC Instruments, Inc.
Circle 398
