Tools and welding
04/01/2005
Water jets and pumps
The website, www.nlb.com, features video clips of water jets performing a variety tasks and an FAQ section filled with helpful charts and tables. Visitors interested in water jet pumps can scroll through diesel, electric, bare shaft pumps, or enter their specifications to see which unit best suits their needs. Data sheets are available for downloading. Quickly find answers to water jetting questions, match pumps to needs, and request quotations.
NLB Corp. nlbcorp.com Write 315 on PE card
Welding cleanup
Scotch-Brite Radial Bristle disks and brushes are tough plastic, rotary tools embedded with sharp Cubitron abrasive grain. They can be used for cleaning metal prior to welding, removing discoloration and sealant, and deburring without damaging the underlying surface. The lightweight bristle brush lasts longer than most abrasives while providing the same cut and finish throughout the life of the product. This reduces changeovers, increases productivity, enhances the finishing process, and reduces labor and downtime.
3M Abrasive systems Div. 3m.com Write 316 on PE card
Utility blades have long life
The LENOX Gold bi-metal utility blade features a titanium nitride coated edge, which offers up to five times life when compared to standard carbon steel blades, making it the longest lasting utility blade on the market. Users can extend the life of these blades even further by using the Gold utility knife, which has a patented titanium-coated stainless steel nose that stands up to the most abusive work situations.
LENOX lenoxsaw.com Write 317 on PE card
Prep heavy wall pipe
MILLHOG Dictator hydraulic ID clamping tool is designed for machining up to 20 inch, Schedule 160 pipe in the field and features only eight sets of clamps for the full working range of the tool. Providing 6500 lbs-ft. of torque, this tool can machine tough material such as chrome-molybdenum and stainless steel pipe without using cutting lubricants. The tool has a self-centering mandrel, dual opposed tapered roller bearings, and titanium nitride coated cutter blades. No special operator training is required.
ESCO Tool escotool.com Write 318 on PE card
Don't lose tools
Tools have sometimes been mistakenly left in machines after maintenance. The consequences can range from lost tools, to expensive and sometimes dangerous damage to a machine. The latter is called foreign object damage or FOD. Mobile Workcenter is a FOD cabinet. Foam inserts in the cabinet's drawers are cut to fit profiles of individual tools. The inserts reduce FOD and tool loss by making it obvious when tools are missing.
Stanley Vidmar stanleyvidmar.com Write 319 on PE card
Dual-purpose pump calibrates
Model PHP pneumatic hand pump is a source of pressure and vacuum. Mount an analog or digital pressure gauge to the top of the unit for a complete calibration system. The pump provides pressures up to 600 psi and vacuum down to -28.5 in. Hg. Higher pressures can be achieved easily and quickly with a minimum number of strokes due to the scissor action design. The pump is fitted with a fine adjustment valve for precise volume control.
Dwyer Instruments, Inc. dwyer-inst.com Write 320 on PE card
Measurement methods
The quality of work performed by maintenance personnel will be significantly improved by using appropriate measurement tools. Measurement Methods computer-based training program describes measurement methods commonly required for day-to-day maintenance. The program is available as a download or on a CD. The program includes training on basic shop math, measurement tools, indirect measurement, and tool calibration and maintenance.
New Standard Institute newstandardinstitute.com Write 321 on PE card
Welding seminar
The Blodgett Welding Design seminar covers essential issues relating to welded structures and weldments such as: determining weld size, controlling distortion, arc welding processes and procedures, mechanical properties of welded connections, cost reduction ideas, metallurgy and why welds crack, non-destructive testing, fracture mechanics, and weld loading. The seminar will be held October 11-13 in Cleveland. To register call 216-383-2240.
The Lincoln Electric Co. lincolnelectric.com Write 322on PE card
