Tips & Tricks
The collision of the creative and practical parts of the brain gives us the world’s great inventions. The basic tools man has invented – the lever, the wheel, the pulley – haven’t been improved on centuries later, but the way those tools are adapted continue to evolve. Electricity is a force of nature and physics, but the taming of that force allows it to move mountains ...
08/15/2007
The collision of the creative and practical parts of the brain gives us the world’s great inventions. The basic tools man has invented %%MDASSML%% the lever, the wheel, the pulley %%MDASSML%% haven’t been improved on centuries later, but the way those tools are adapted continue to evolve. Electricity is a force of nature and physics, but the taming of that force allows it to move mountains and still remain safe to use.
This is how Tips & Tricks was born 20 years ago %%MDASSML%% by facing the problems we see each day on the plant floor and crafting a creative solution. Hundreds of great ideas over two decades have helped PLANT ENGINEERING readers out of tight spots and helped get the job done safely and efficiently.
Even in today’s high-tech world, the basics of tools and nature haven’t changed. How we use them has changed dramatically. But there always will be room in a high-tech world for innovative ways to move motors, measure voltage or simply fill in a hole. Here are the 2007 contributions from PLANT ENGINEERING readers to the legacy of Tips & Tricks:
Moving motors to change bearings
When changing a bearing, coupling, etc. the motor normally needs to be moved out of the way to access the equipment. For heavier motors, remove the motor mounting bolts, disconnect the coupling and lift each foot with a small flat pry bar. Put a 1/8” x 4” nipple under each foot and roll the motor out of the way. Once out of the way place a washer in front of and behind two of the roller pipes to keep it place. After repairs, remove the washers and roll it back into place and remove the roller pipes.
Jack Jones
Electrical Engineer
Guardian Industries Corp., Pittsburgh
Saw in reverse
When cutting PVC with a hole saw. Run the saw in reverse and the holesaw will not twist and jerk out of your hand.
Ken Borgen
Maintenance & Facilities Manager
The Michaels Furniture Co., Sacramento, CA
Test lights as indicators
I find neon test lights to be handy when used as intended, but also as indicator lights. Cut off the tips, crimp on terminals, and install across AC components. Use several, as test lights are inexpensive, have a wide-voltage AC range, and don’t take up much space. Troubleshooting is easier when watching a sequence of events. I leave them in place, because there is not much reason to pull them out. Watching them helps explain operating details to someone else.
Craig Cox
Project Engineer
Corporate Engineering, Racine, WI
Filling the gap
When filling in a hole that has been worn open past an acceptable tolerance, a piece of copper pipe (with an outside dimension of the size that is needed) can be inserted into the hole. A welder can fill the gap between the worn sides of the hole and the copper pipe. When the welding is complete, simply knock-out the piece of pipe.
Gary Hawkins
Plant Engineering Supervisor
3M, Nevada, MO
Testing fan speeds
Hinge a small vane in the moving air so it rests on a contact point that triggers a solid state relay, Adjust the vane’s weight so the switch opens when the fan’s speed is higher than desired. When it slows down, the contact closes and the speed increases. The switch contact can be optical to avoid the exposed arc of a true mechanical point contact.
Craig Cox
Project Engineer
Protecting bump strips
On automatic doors, when there is a bump-strip to prevent shutting while anything is in the way, a flexible piece of material can be used to cover the bump-strip so that if an item such as a pallet jack in the door is moving when the bump-strip is contacted it will not pull the bump-strip out of its track.
Gary Hawkins
3M, Nevada, MO
Testing for loss of ground
Use a non-contact voltage tester for the loss of ground to electrical equipment. Test first in an outlet, then hold the tester close to the metal case of a piece of equipment connected to the outlet with a three-prong plug. If properly grounded, the probe will not light or sound. Then connect the three-prong plug to a two-prong adapter. Plug into an outlet, and then hold the voltage probe close to the metal case. The probe will sound and light indicating voltage.
Bennie Kennedy
General Industries Outreach Electrical Safety Trainer
Square D/Schneider Electric
