TF450 Laser marking machine
This laser solution takes advantage of all the benefits of it’s fiber laser source including: long life, consistent marking quality, minimized integration costs and reduced maintenance.
The TF450 beam vaporizes material, creating a completely unalterable marking. This allows use with multiple materials such as steel, stainless steel, aluminum, copper, and brass as well as industrial applications like: automotive, fittings, metallurgy, cutlery, armory, medical industry, and many more.
The machine has even been tested and approved for the cutting of thin metal sheets up to 3 mm (.118") thick.
Technifor
www.technifor.us
