Terminal blocks provide safe disconnect in CT shorting applications
These test disconnect terminal blocks provide safe disconnect capability between measuring transducers and safety equipment in current transformer (CT) shorting applications.
04/07/2009
ME test disconnect terminal blocks
The ME test disconnect terminal blocks provide safe disconnect capability between measuring transducers and safety equipment in current transformer (CT) shorting applications. The screw-free disconnect lever provides visual indication of the switch’s position. Designed for use in such industries as power generation, utilities and semiconductor manufacturing, these terminals can be used wherever high currents must be reduced using current transformers, and where high voltages are reduced with voltage transducers. To accomplish the safe disconnect, the operator places switchable ME test disconnect terminal blocks before the meter for measurement and maintenance.
Each terminal block has a set of three bridging channels on either side of the disconnect lever. The pluggable shorting component can lock into one of the bridging channels. Even with the shorting component installed, two bridging channels remain available for use. The test disconnect terminal blocks, ground and feed-through terminal blocks have the same pitch and profile. All are available with screw, spring-cage and push-in connection technologies.
Phoenix Contact
www.phoenixcontact.com/meseries
