Tank air breather removes ambient contaminants
TriCeptor disposable hydraulic tank breather protects the reservoir and work environment in a three-step process by removing solid particles and water from entering the tank and collecting oil mist before it exits. Filter pads eliminate solid particulate.
By Staff November 1, 1998
TriCeptor disposable hydraulic tank breather protects the reservoir and work environment in a three-step process by removing solid particles and water from entering the tank and collecting oil mist before it exits. Filter pads eliminate solid particulate. Silica gel desiccant removes humidity and condensation. Activated carbon removes oil vapors and associated odors. Parker Hannifin Corp., Hydraulic Filter Div.
