System monitors lubricant condition
Oil Security System continuously performs on-line monitoring of lubricant quality on rotating equipment. It provides automatic viscosity and temperature measurements and water contamination indication.
Oil Security System continuously performs on-line monitoring of lubricant quality on rotating equipment. It provides automatic viscosity and temperature measurements and water contamination indication. Visual indications signal safe, caution, and alarm conditions. The precise status of viscosity, water content, oil temperature, and time remaining until the next oil change can be obtained at any time.
Trico Mfg. Corp.
www.tricomfg.com
Circle 388
