Synchronizing compressors
Problem: Summer workloads may cause the main air compressor to overheat. How can you synchronize the backup with the main machine? Solution: Hook up a repeat cycle timing relay with an on/off switch to the backup compressor and adjust.
Solution: Hook up a repeat cycle timing relay with an on/off switch to the backup compressor and adjust. For example, on 1 min, off 2 min, at a 33% duty cycle. Off-time can be adjusted up or down to handle slow or busy days.
Contributor: Ronald Butterfield, Maintenance Manager, Mercury Luggage, Jacksonville, FL; 904-733-9595
