Switch components: Mini slide switches, illuminated tactile switches
C&K Components miniature slide switches and E-Switch illuminated right-angle tact switch with through-hole termination and blue, red, green, and yellow LEDs can help embedded device design.
09/04/2008
Newton MA, and Minneapolis, MN – Electronic and embedded device designers and panel builders may have an easier time with introduction of C&K Components miniature slide switches and with an E-Switch illuminated right-angle tact switch with through-hole termination and blue, red, green, and yellow LEDs.
C&K Components miniature slide switches just 1.5 mm high.
C&K Components miniature slide switches are just 1.5 mm high.
RoHS-compliant, process compatible switches offered in multiple configurations:allows some devices to sit less than 0.7 mm high. Mounting options are said to make the slide switches ideal for applications such as remote control equipment, instrumentation, test and measurement equipment, computer peripherals, and mobile telecommunications.
The switches are available with one or two poles, feature double- and triple-throw action, and offset or side actuation. Contact resistance is less than 80 milliOhms with life cycles to 10,000 operations.
The sub-miniature JS Series slide switches feature a profile down to 0.7mm, positive detents, high contact reliability and right or center actuation, and can be surface or through-hole mounted. Available in SPDT, DPDT and DP3T models, the switches have IR reflows to 260° solder profile, contact rating of 6 V dc @ 3 A and life cycles to 5,000 operations.
Similar to the JS Series slide switches, the JSM Series switches also feature positive detents, IR reflow to 260° solder profile, and can be surface or through-hole mounted. The JSM switches are offered in SPDT, SP3T models and feature maintained and momentary functions. Contact rating is 4 V dc @ 0.3 A, with lifespan to 10,000 cycles.
The PCM Series ultra miniature surface mount slide switches are available in SPDT and SP3T models. Contact rating is 6 V dc @ 0.3 A, with a mechanical life to 50,000 cycles. The switches are available in tape and reel packaging.
Pricing for the JSM Series slide switches ranges from $0.60 to $0.70. The switches are offered in 1,800-piece reels.
The company
Get more information on C&K Components’ AYZ, JS, JSM, PCM miniature slide switches .
E-Switch TL1290 illuminated tactile switch
E-Switch announces a new illuminated tactile switch : E-Switch announces the TL1290, the latest in illuminated tactile switch offerings. This right angle switch has through-hole termination and offers of blue, red green and yellow LEDs. The company says it
Specifications include:
Electrical life– 25,000 cycles;
Operating force– 500 +/- 125 gmf;
Contact rating– 100 mA @ 32 V dc;
Contact resistance– 250 mΩ max (initial);
Insulation resistance– 100 MΩ (min @ 500 V dc);
Dielectric strength– 250 V ac; and
Operating temperature range
Markets include testing and instrumentation, audio/visual, medical, telecommunications, and computer/servers/peripherals, and consumer electronics, among others.
The company is offering free samples of more than 4,000 part numbers, including rocker, toggle, slide, tactile, pushbutton, dip, rotary, keylock, snap action, detector, and other switches.
– Edited by  Mark T. Hoske , editor in chief
Control Engineering System Integration eNewsletter
Register here and scroll down to select your choice of eNewsletters free .
