Stepper drive
The ST10-Q is equipped with eight digital inputs, four digital outputs and two analog inputs, with 24-80 Vdc input and output current to 10.0 A peak.
The ST10-Q is equipped with eight digital inputs, four digital outputs and two analog inputs, with 24-80 Vdc input and output current to 10.0 A peak. Demand signal smoothing reduces extraneous system resonances while providing smoother motor performance. Torque ripple smoothing adjusts the current waveform to reduce low speed torque ripple, and MicroStep emulation provides smooth motion for systems that require low step resolutions. Self-test and auto setup features measure and configure motor parameters automatically, while anti-resonance technology eliminates midrange instability for higher motor speeds and fuller use of available torque.
Applied Motion Products
