Stainless steel take-up frames
MRC stainless steel take-up frames for use in food-industry conveyor systems are designed to provide support for conveyor shafts and deliver correct conveyor belt tension while withstanding frequent washdowns and typically harsh chemicals.
MRC stainless steel take-up frames for use in food-industry conveyor systems are designed to provide support for conveyor shafts and deliver correct conveyor belt tension while withstanding frequent washdowns and typically harsh chemicals. Frames are available in two styles (wide and narrow) and in a range of frame sizes. They can be installed to conveyor systems (usually at the idler end) with four mounting bolts. Units are lubricated for life with USDA food-grade grease.
SKF USA Inc.
www.skfusa.com/mrc
