Stainless steel pneumatic cylinders
Constructed of 303 and 304 stainless steel, these cylinders can be used in wash-down and caustic environments.
Designed for use in a broad range of applications including those in wash-down and caustic environments, these cylinders are constructed of 303 and 304 stainless steel. They include a rod wiper to keep potential contaminants from penetrating inside the cylinder, and are available with bore sizes from 3/4 in to 2-in. Standard stroke lengths are from 1 in up to 32-in. on some models. These pneumatic cylinders also come with precision rolled construction for leak-proof operations and interchangeable design for a wide range of applications.
Clippard
www.clippard.com
