Stackable solenoid valve
The versatile 3900 solenoid valve series can be stacked into a multiple output bank of solenoid valves with a single inlet.
The versatile 3900 solenoid valve series can be stacked into a multiple output bank of solenoid valves with a single inlet. The two-way, two-position or three-way, two-position, direct-acting normally closed valves feature a fully encapsulated coil, spring compensated plunger seats, a pressure range of vacuum to 150 psi, and a miniature stackable body in either aluminum or stainless steel. The coils are available with DIN quick-connect pin-out wire leads or with DIN connectors installed.
Spartan Scientific
www.spartanscientific.com
