Speed reducers
A line of worm gear speed reducers is covered in an 8-p brochure. A wide selection of ratios is offered in single and double reduction models. Output speeds range from 0.5-500 rpm, and torques up to 20,000 in.-lb.
By Staff September 1, 1998
A line of worm gear speed reducers is covered in an 8-p brochure. A wide selection of ratios is offered in single and double reduction models. Output speeds range from 0.5-500 rpm, and torques up to 20,000 in.-lb. Offerings include washdown models, various bases and flanges, and shaft mount units.
Baldor Electric Co.
www.baldor.com
