Speed bump
The one way speed bump is designed to allow traffic to pass over it on one side while restricting the flow of traffic on the other side. A 2-inch upright barrier edge features a reflective sign indicating “wrong way” to deter traffic, and a notch cut along the bottom allows wires and cords to run underneath.
The one way speed bump is designed to allow traffic to pass over it on one side while restricting the flow of traffic on the other side. A 2-inch upright barrier edge features a reflective sign indicating “wrong way” to deter traffic, and a notch cut along the bottom allows wires and cords to run underneath. The unit is constructed of recycled plastic and wood and resists dents, corrosion and cracking.
New Pig Corp. : www.newpig.com
