Spark-resistant cables
When fully mated the cables are rated IP67 to ensure protection from liquids and debris.
The PUR cable ensures a resistance to sparks, wear, impact and flexibility. The new M12 A-coded cordsets are ideally suited for robot welding lines in the automation industry. Standard versions have 3, 4, and 5 gold-plated contacts with a rated current of 4A each. A maximum rated voltage ranges from 125V-250V based on the number of contacts. When fully mated the cables are rated IP67 to ensure protection from liquids and debris. The UL approved cables are available in black and orange with the option of 2m or 5m lengths. The standard cable has a wire gauge of 22AWG with a PUR jacket material
Binder
