Self-loading gasket
The Multi-Swell self-loading gasket creates its own load when coming into contact with water or oil. Exhibiting high crush strength and to be easily cut and installed, the gasket is suitable for a range of applications. Its adaptable to most types of flange designs, capable of sealing both ring and full-face, standard ANSI flanges, difficult-to-seal cast-iron flanges, specialty OEM designs and ...
By Staff November 1, 2006
The Multi-Swell self-loading gasket creates its own load when coming into contact with water or oil. Exhibiting high crush strength and to be easily cut and installed, the gasket is suitable for a range of applications. Its adaptable to most types of flange designs, capable of sealing both ring and full-face, standard ANSI flanges, difficult-to-seal cast-iron flanges, specialty OEM designs and non-metallic flanges.
Garlock Sealing Technologies; Gasketing Div. : www.garlock.com
