Self-configuring digital signal conditioner
The digital signal conditioner technology simplifies the use of eddy current (inductive) displacement sensors for high precision/high reliability applications.
By Kaman Precision Products August 29, 2016
The digital signal conditioner technology simplifies the use of eddy current (inductive) displacement sensors for high precision/high reliability applications. The technology is ideal for monitoring movement, position, vibration, alignment, or deflection, especially where parts operate in high temperatures or within environmental contaminants. It features programmable functions such as relay set points for indication of out of tolerance conditions or process control, digital low pass filtering to improve resolution, adjustable sensor sample rate, and a quick 2-point adjustment instead of full calibration when replacing broken sensors.
www.kamansensor.com
