Section valve
A new modular hydraulic mobile sectional valve offers absolute flexibility for a broad range of mobile applications. The new CM 120 valve combines proven modular design features with the ability to use Screw-In Cartridge Valve (SICV) technology to give users a wide choice of configuration options. CM120 valves are an open center, parallel circuit architecture and available in configurations wit...
October 1, 2009
A new modular hydraulic mobile sectional valve offers absolute flexibility for a broad range of mobile applications. The new CM 120 valve combines proven modular design features with the ability to use Screw-In Cartridge Valve (SICV) technology to give users a wide choice of configuration options. CM120 valves are an open center, parallel circuit architecture and available in configurations with up to 10 operating sections. Rated flow is 120 lpm (32.7 gpm) and they are rated at 250 bar (3,625 psi) using the NFPA T.2.6.1 protocol, giving them a maximum pressure of 290 bar (4,200 psi).
Eaton
www.eaton.com/hydraulics
