Seals replace conventional packing
The 11K EZ Stack Pack hydraulic seals replace conventional "chevron" packing. The two-part (blue and red polymer) stacked set rod seal is split and does not require shimming or adjustment.
The 11K EZ Stack Pack hydraulic seals replace conventional “chevron” packing. The two-part (blue and red polymer) stacked set rod seal is split and does not require shimming or adjustment. The hard and soft materials provide anti-extrusion and conformability to new and old equipment. The split configuration simplifies installation and decreases downtime.
A.W. Chesterton Co., Hydraulic/Pneumatic Business; www.chesterton.com
TO VOTE, WRITE 185 ON BALLOT
For more information, circle 421 on card
