Screwdrivers bend, loop, and connect wire
Wire bending screwdrivers position a handle-mounted, short wire-bending stud parallel to the driver's blade providing a quick and easy way to bend, loop, and connect solid #10 - #14 wire. The tools are available in round shank, No. 1 and No.
By Staff September 1, 1998
Wire bending screwdrivers position a handle-mounted, short wire-bending stud parallel to the driver’s blade providing a quick and easy way to bend, loop, and connect solid #10 – #14 wire. The tools are available in round shank, No. 1 and No. 2, Phillips tip, heavy-duty round shank 1/4 in. cabinet-tip, and round shank No. 1 and 2 square-recess-tip.
Klein Tools
