Screw conveyor seals
HB model seals are in stock in five CEMA and eleven metric shaft sizes: from 1-½ inches to 3-7/16 inches and from 40 mm to 90 mm. HB seals are designed to perform under 90% of typical operating conditions for screw conveyors. This includes food-grade applications, temperatures up to 500 F, shaft run-out up to ¼ inch and vertical or inclined shafts.
MECO www.mecoseal.com
