Schneider Electric powers up photovoltaic solar array project at Palatine headquarters
See 5 solar project implementation tips based on an installation that's part of Schneider Electric's commitment to new technologies and environmental responsibility. It has rated output of 60.5 kW, and 232 modules mounted on 29 unique "flower" pole arrays. See photos, diagrams.
12/11/2009
5 implementation tips: Photovoltaic solar array advice from the project manager
Schneider Electric photovoltaic solar panels during construction
Schneider Electric
Schneider Electric's Vincent Throop served as project manager for photovoltaic installation in Palatine, IL. Photo by Mark T. Hoske.
VincentThroop, senior application engineer, North American Operating Division,Schneider Electric, served as project manager for the installation. Hegave some friendly advice during the first hour of power:
1. Contactplanning and zoning and local electric utility representatives first.Turns out this was the first such project in the area, so everyone wasbreaking new ground.
2. Produce renderings of the project early on to help educate all involved.
3.Timing: "While we started a year ago, depending on project size, weprobably could have finished in four or five months, if we devoted alittle more time to it."
4. Optimization versus complexity: Whilethe 8-cell panels could follow the sun, these do not; to do so was notdeemed worth the costs involved.
5. Find strong partners . SchneiderElectric thanked many for help with the project, including electricalcontractor, JC Power & Control Inc., www.jcpower.com.
- Mark T. Hoske, online products editor, Manufacturing Business Technology , MBT www.mbtmag.com
Schneider Electric, a global specialist in energy management, announced the unveiling of the largest corporate solar array installation in Illinois history. The array will reduce electric usage at its North America headquarters facility by an estimated 2%-3% annually, company officials said, as they powered up the installation on a below-freezing Dec. 10.
James Schwantz, mayor of Palatine, IL, and other local government officials and dignitaries attended the renewable project launch, among others.
Schneider Electric Chris Curtis says Schneider helps make energy safe, reliable, efficient, productive, and green - photo by Mark T. Hoske.
Chris Curtis, CEO of Schneider Electric's Buildings and Power North America business, said the installation "showcases how the use of energy efficient and renewable solutions together play key roles in solving our energy dilemma. We hope to serve as an inspiration and resource for other businesses as the demand for sustainable energy continues to grow."
Curtis said the installation is part of Schneider Electric's commitment to help make people make the most of their energy. The photovoltaic (PV) solar project includes a special "flower" type mounting system, consisting of 232 modules with 29 pole supports, solar panels, Schneider Electric Xantrex inverter, Schneider Electric metering and monitoring equipment, and all the electric wiring needed to harness the power. The PV system has a rated output of 60.5 kW which will vary according to sun angle, time of year, and weather conditions, and is designed to withstand high winds and snow.
Schneider Electric touchscreen shows carbon offset and other information.
Interactive touchscreen in the Schneider Electric cafeteria shows the carbon offset the project provides cumulative tally of environmental benefits, as this sample screen shows. Annual carbon offset is estimated at 89,166 lb.
An educational "Green display" using Schneider Electric's PowerLogic monitoring and metering systems is part of the installation. This display is located inside the facility and educates users and visitors by displaying real time information about current energy generated, usage, and the amount of CO2 emissions reduction.
Payback: 10 years
Valued at $750,000, the installation qualified for a 30 percent federal tax credit, an accelerated federal depreciation schedule (MACRS), a state incentive of $3.25 per dc watt, and the sale of Renewable Energy Credits (RECs). The system - which uses Schneider Electric's Xantrex Inverter to convert the solar power into energy - has an expected life of 40-years.
Schneider Electric solar diagram
The installation will "build on our history of working with large scale PV systems," said Curtis. "Our goal is to demonstrate to Schneider Electric customers our ability to safely control, meter, and transform dc power using the inverter produced by our Renewable Energies division and PMO metering division."
Schneider Electric inverter
Schneider Electric inverter for the solar photovoltaic project converts dc to ac.
Amendments to zoning
During the six months of construction, Schneider Electric worked with the Village of Palatine to amend the zoning and permitting process to include solar projects. The Palatine building was identified as the best site within the company to install the system based on the rebates and incentives available in the region. The installation precedes the facility's LEED certification, which is being actively pursued for 2010.
Schneider Electric goes green(er) with a solar project at North American headquarters.
Schneider Electric is proud to be in a position to consult and partner with companies seeking clear plans to manage energy, increase energy efficiency, and meet demands for renewable energy.
Key project points
While the project would cost others about $750,000, Schneider Electric's cost was about $550,000 (with company discount on switchgear, inverter, and related equipment). With local and federal incentives, payback is estimated at 10 years.
Panels, with a 25 year warranty, are expected to last about 40 years. Total output is 60.5 kW dc or 50.1 kW ac, depending on angle and strength of sunlight.
The inverter converts power from dc to ac and ensure optimal use. No electricity is expected to flow beyond the building, as it will provide, at most 3% of the all-electric facility's needs; Commonwealth Edison representatives were on hand to help ensure safe startup. Inverter photo was taken during construction.
www.schneider-electric.us
Also read from MBT: SAP walks the talk on solar panels .
More photos, added Dec. 11, follow, below.
- Edited by Mark T. Hoske, online products editor, Manufacturing Business Technology , MBT www.mbtmag.com
Schneider Electric solar farm in Palatine, IL, includes Square D and other Schneider Electric products, says Chris Curtis, CEO of Schneider Electric
Schneider Electric solar farm in Palatine, IL, includes Square D and other Schneider Electric products, says Chris Curtis, CEO of Schneider Electric's Buildings and Power North America business - photo by Mark T. Hoske.
Schneider Electric
Schneider Electric's Chris Curtis in front of about 2.1 kW of dc power generation, 1 of 29 solar "flower" poles, at the Palatine, IL, headquarters - photo by Michael Ivanovich.
Schneider Electric personnel head south to inspect the solar farm on a frosty Dec. 10, 2009 - photo by Michael Ivanovich.
Schneider Electric photovoltaic solar farm in Palatine, IL - Mark T. Hoske photo
Schneider Electric  solar dashboard also shows a diagram of arrays with status, alarm conditions, and other information - photo by Mark T. Hoske.
Schneider Electric North American headquarters, Palatine, IL, as it appears on the solar dashboard. Arrays, not visible, are to the south - photo by Mark T. Hoske.
Schneider Electric makes the inverter and switchgear for its solar installation; total output is 50.1 kW ac. Solar project ROI is estimated at 10 years  - photo by Mark T. Hoske.
Schneider Electric inverter human-machine interface - photo by Mark T. Hoske.
