Safety interlock switches, up to 6 contacts
The D4SL-N Safety Interlock Switches by Omron STI is available with up to 6 contacts, can be mounted in any direction and allows users to change the key insertion point without detaching the head.
Omron Automation and Safety's D4SL-N Safety Interlock Switches are available with 4-, 5- or 6-contacts to satisfy many application needs. The IP67-rated D4SL-N can be mounted in four different directions without needing to rotate the head. Two wiring methods minimize wiring time and make possible one-touch attachment and removal. Easy to view LED indicators allow users to quickly check switch status from any direction. D4SL-N safety switches deliver a minimum of 1 million operations and boast a minimum key holding force of 1300 N to maximize the range of potential applications that can benefit from a tough, compact safety switch.
D4SL-N switches are available with two types of wiring. Connector-type wiring models feature a connector cable that reduces the potential for mis-wiring, facilitates fast maintenance, and allows easy switch replacement in the event a switch is damaged. Terminal block-type models include a detachable terminal block to significantly increase wiring efficiency.
6-contact versions of the D4SL-N safety switch enable users to independently monitor door open/closed status, as well as solenoid on/off status, from a single switch. An optional slide key prevents workers from becoming trapped inside the hazardous area, without having to use a padlock.
Omron STI
