Safety instrumented system device identification tags
Safety instrumented system device identification tags provide visibility and durability in the process industry.
Safety instrumented system device identification tags provide visibility and durability under extreme conditions including heat, humidity, long-term exposure to weather, UV, salt spray, abrasion, industrial solvents, and chemicals. The tags are designed for smaller SIS devices including switches, transmitters, and solenoids. The tags can be customized with user defined bar code for asset management and CMMS identification. An optional Tag-Tite tamper evident tag retention device can securely fasten the SIS-TAG to ensure adherence to management of change procedures. The Tag-Tite features an anodized aluminum locking body with an 18-in. adjustable length stainless steel cable and stainless steel hardware.
Sis-Tag
www.shop.sis-tag.com
