Rugged connectors
A new IP67-Rated Metal-Shell ODVA-Compliant connector allows industrial Ethernet to be applied in rugged environments. The Zamak zinc-alloy metal shell gives additional mechanical strength, while the IP67 sealing protects the interface from liquids, gases, and other contaminants. The connectors meet Category 5e performance requirements.
By Plant Engineering Staff August 1, 2009
A new IP67-Rated Metal-Shell ODVA-Compliant connector allows industrial Ethernet to be applied in rugged environments. The Zamak zinc-alloy metal shell gives additional mechanical strength, while the IP67 sealing protects the interface from liquids, gases, and other contaminants. The connectors meet Category 5e performance requirements. The 8-position connectors are available in plugs or receptacles, either shielded or unshielded, with end caps to protect unmated connectors. The quick-turn bayonet coupling and positive locking ring provide reliable connections.
Tyco Electronics , www.tycoelectronics.com
