Rotor insertion flowmeter
The RIM20 is ideal for measurement of mass or volumetric flow, density, temperature and pressure.
The RIM20 is ideal for measurement of mass or volumetric flow, density, temperature and pressure. Typical applications include measurement of steam and natural gas flows for fiscal or load control and heat flow calculations for chilled, hot water and a variety of other liquids and gases in line sizes from 3 to 80 in. The RIM20 low-mass rotor design is fabricated from a single solid block of stainless steel, with no welded joints. There are six field-installable cartridges with different turbine pitches with NIST traceability. This field configuration versatility, plus a wide 25:1 turndown, enables the flowmeter to match flow rates precisely.
Spirax Sarco, Inc.
