Right-angle cable assemblies
Sixteen low profile, right angle, high performance flexible cable assemblies are designed for Type-N, TNC, and SMA cables and cover frequency ranges to 26.6 GHz.
By Fairview Microwave September 22, 2015
Sixteen low profile, right angle, high performance flexible cable assemblies that are suitable for Type-N, TNC, and SMA cables and cover frequency ranges to 26.6 GHz. These cables provide a flexible coax alternative that incorporates a double shielded wire braid over foil tape construction, which results in high isolation in excess of 90 dB. They are ideal in system applications where flexibility is needed when routing tight cables in tight enclosures. They include operating temperature range of -40 to 150 C and stainless steel connectors with a minimum lifespan of 500 mating cycles.
Fairview Microwave
www.fairviewmicrowave.com
