Retractable sensor housings
The InTrac 781/784 series of retractable sensor housings with locking systems are designed to tolerate extreme process conditions such as chemical, petrochemical, pulp and paper, or utilities applications.
By Mettler Toledo December 4, 2015
The InTrac 781/784 series of retractable sensor housings with locking systems are designed to tolerate extreme process conditions such as chemical, petrochemical, pulp and paper, or utilities applications. The locking system provides operating safety and the user can remove the probe only when the insertion is fully retracted, which avoids any unintended sensor removal when it is in the measuring position. The housings allow sensor maintenance and exchange without any interruption to the running process. The stainless steel version of the housing allows sensor deployment or retraction in up to 16 bar with no compromise to operator safety.
Mettler Toledo
www.mt.com
