Rental package installs outdoors
TSR-20 rental air compressor package is designed specifically for outdoor installations. It saves 11-13% in energy over single stage compressors and has a 5-yr warranty on the air end and variable speed drive system.
By Staff November 1, 1999
TSR-20 rental air compressor package is designed specifically for outdoor installations. It saves 11-13% in energy over single stage compressors and has a 5-yr warranty on the air end and variable speed drive system. Application flexibility is achieved from a wide variety of pressures and capacities available. The versatile control system, coupled with a spiral valve, provides optimum part load control.
Sullair Corp.; www.sullaircompressors.com
TO VOTE, WRITE 134 ON BALLOT
For more information, circle 375 on card
