Remembering the right order
Problem: Repair of the flowmeter (or any other item with numerous small parts) is complete, and its time to reassemble the package. Staring at the pile of pieces might seem like a puzzle that has to be put together.
Problem: Repair of the flowmeter (or any other item with numerous small parts) is complete, and its time to reassemble the package. Staring at the pile of pieces might seem like a puzzle that has to be put together. Is there a routine for easy reassembly of the product?
Solution: Purchase a calendar with large squares. As the parts are initially removed, spot them on succeeding numbers. Reversing the order easily gets the product back together.
Contributor: George Patrelakis, Weirton Steel Corp., Weirton, WV
