Regulated and isolated dc/dc converters
Murata's dc/dc converters from MTC2 series of 2 W single output are available with 12 or 24 Vdc 2:1 input voltage range and output voltages of 3.3, 5, or 12 Vdc.
Murata’s MTC2 series of regulated and isolated dc/dc converters from are available with 12 or 24 Vdc 2:1 input voltage range and output voltages of 3.3, 5, or 12 Vdc. Measuring just 0.59 by 0.56 by 0.44 in the converter complies with both the UL/EN 60950 reinforced insulation safety standard for use in commercial equipment and the ANSI/AAMI ES60601-1 medical safety specification. The MTC2 has an input range of 2:1 and is capable of accommodating applications where there may be wide deviations of the input voltage. A remote on/off pin is available to aid sequencing power start-up in a design or to enable application power saving features. A continuous short circuit protection function ensures that both the load and the device are protected from short circuit conditions.
Murata Power Systems
Power Products | Electronic Components | Murata Manufacturing Co., Ltd.
– Edited by CFE Media. See more Control Engineering energy and power products.
