Refrigeration, air conditioning equipment
The Qwik system flush is a biodegradable, non-toxic and non-flammable removal system for residual oil, moisture and acid in refrigeration and air conditioning equipment.
By Plant Engineering Staff April 4, 2008
The Qwik system flush is a biodegradable, non-toxic and non-flammable removal system for residual oil, moisture and acid in refrigeration and air conditioning equipment. The system leaves no residue if a system is properly evacuated down to 25 inches of mercury. It provides a cleaning solution for line sets amidst HCFC to HFC conversions, evaporators, condensers and line sets after a system burnout, systems suffering from excess moisture, and preventive maintenance programs in suspect systems. Mainstream Engineering www.mainstream-engr.com
