Reducer features wobble-free bushing system
K Series helical/bevel speed reducer is supplied with a double-sided wobble-free bushing system that allows the unit to be mounted on the shaft from either side of the reducer.
By Staff November 1, 1999
K Series helical/bevel speed reducer is supplied with a double-sided wobble-free bushing system that allows the unit to be mounted on the shaft from either side of the reducer. The corrosion resistant reducer features a distinct support side and clamp side, and dual tapered cones to overcome a wide range of tolerances normally found with standard shaft materials.
Stober Drives, Inc.; www. stober.com
TO VOTE, WRITE 71 ON BALLOT
For more information, circle 411 on card
