Racking device reduces arc flash exposure
Low Voltage Switchgear Remote Racking Device allows users to rack circuit breakers in and out from up to 30 feet away, drastically reducing the potential for an arc flash injury. The electric motor is operated using 115 Vac via plug-in power cord. The gearbox is easily attached to the front of the circuit breaker with a sliding latch connection.
Low Voltage Switchgear Remote Racking Device allows users to rack circuit breakers in and out from up to 30 feet away, drastically reducing the potential for an arc flash injury. The electric motor is operated using 115 Vac via plug-in power cord. The gearbox is easily attached to the front of the circuit breaker with a sliding latch connection. Unit is available as retrofit or option with LV switchgear. General Electric : www.geelectrical.com
TO VOTE, WRITE 72 ON BALLOT
For more information, write 72 on card
