Push-in terminal blocks
Modular PIT terminal blocks use push-in technology to reduce insertion force by 50%. The terminal blocks are easy to operate, reduce fatigue and are suitable for installations with limited space or hard-to-access wiring. Available in a 2.5-square-mm cross section, the terminal blocks accept ferrules of 22 to 14 AWG.
March 1, 2010
Modular PIT terminal blocks use push-in technology to reduce insertion force by 50%. The terminal blocks are easy to operate, reduce fatigue and are suitable for installations with limited space or hard-to-access wiring. Available in a 2.5-square-mm cross section, the terminal blocks accept ferrules of 22 to 14 AWG. The series features feed-through, multi-level function, component and pluggable terminal blocks.
Phoenix Contact www.phoenixcontact.com
