Pump with reusable and replaceable stator
iFD-Stator 2.0 features a two-part, reusable stator housing and replaceable stator while being compatible with NEMO NM series progressing cavity pumps.
Netzsch Pumps’ iFD-Stator 2.0 features a two-part, reusable stator housing and replaceable stator while being compatible with NEMO NM series progressing cavity pumps. The defined compression for the iFD-Stator 2.0 is automatically generated when the elastomer collar is fastened. The axial mobility of the elastomer leads to a long service lifetime of the stator. The pump is available in eleven styles with four rotor/stator geometries and a selection of engineered joints that can be tailored to suit specific applications. Conveyance volumes can be configured in proportion to rotation speed, with high dosing precision over the entire rotational-speed range.
Netzsch Pumps
