Pulverizer tailored to match system requirements
Mikro Long Gap Mill is a single shaft, air swept mechanical pulverizer.
Mikro Long Gap Mill is a single shaft, air swept mechanical pulverizer. Variable rotor height to diameter ratios and adjustable gap clearances, tip speeds, and coarse extraction, coupled with independent or single shaft classifier, allow the impact/flash dryer to match any requirement.
Hosokawa Micron Powder Systems; www.hosokawamicron.com
TO VOTE, WRITE 105 ON BALLOT
For more information, circle 386 on card
