Pulling more wires
Problem: Pulling additional wires through an existing conduit run can be a risky task, even if the conduit size and fill restrictions allow for additional conductors. Solution: Instead of a fish tape, use one of the existing wires.
Solution: Instead of a fish tape, use one of the existing wires. Attach the wires to be added (plus a replacement for the one to be removed) to an end of one of the existing wires. Pull the old wire out and the new ones in.
Contributor: J. Michael Stone, Smurfit Stone Container Corp., Greensboro, NC; 336-273-8201
